My suspicion is that the bulbs are getting blamed erroneously because bright white stands out.
The real issue is the failure to legislate for SUVs to have a similar headlight height to other cars.
Sit in a sports car and their headlights are at eye level. Designed to dazzle by design and legislation oversight.
The LED H4 bulbs are often deemed to have a poor beam when the real issue is that many are supplied in 2 parts (3 pronged adaptor bit that clips into the head unit) and the bulb element which fits into the adapter. A flaw with a great many of these are that bulb and adaptor can be mounted in 2 ways - the correct way for the bulb to give the correct dip beam when in the lens unit or 180 degrees out, in which case you get an incorrect scattered beam.
Much of the negative comments are from those whose bulb is effectively mounted upside down. Sadly the instructions rarely mention this and you only find out when you discover the two parts can be separated. (Also needed if you wish to fit the covers which won’t fit over the heat sink)
The images show the two ways and the arrows point to the shrouding to make the dipped beam work.
If you stand in front of your car with the headlights on dip you should be able to bend down and see where the beam cut-off is.
From this you should be able to see if it is interferring with other road users.
For my dip I need to bend down a significant way. Also you can tell if it is pointing to the kerb side or straight on etc.
This agrees with my MOT results and the cut-off pattern on the garage wall.
My exchange with Darren was an interesting read from someone clearly on his game. Partially because the legislation is not baked & approved yet and other because the timeline to when such regulation could come into effect is still not known. My thoughts mirror his that the more classic car owners who raise objections &/or clarifications to your local MP the better. MPs get hit with loads of AI-generated carp and on this matter, to me it seems there are several issues that the technicalities and emotional/practicalities are not equal.
Of course there's the other thing that might happen as it is highly rumoured to happen with certain Lotus 7ish cars. Their cataclysmic perverters appear on their cars for MoT then somehow magically fall off afterwards. Or so I've heard 🙃
  • 3 weeks later...
Darren has been on top of the entire matter and shared the folling important update yesterday:
There has been an exemption added to the MoT regulations which we are grateful for and affects your vehicle:
Headlamp conversions and replacement light sources:
For vehicles first used before 1 April 1986, light source compatibility with the headlamp unit is not assessed as part of the MOT test, and is not a reason for rejection.
If you are changing a halogen lamp to an LED in a halogen headlight unit the beam pattern must pass the standard MOT beam pattern test which our LEDs will if they are adjusted properly and fitted to a suitable headlight unit.
For vehicles first used on or after 1 April 1986, existing halogen headlamp units must not be converted to be used with either:
- high intensity discharge (HID) light sources
- an LED replacement light source (LEDr) that has not been approved for use in that lamp.
A halogen headlamp unit fitted with an LED replacement light source (LEDr) may be accepted where the LEDr light source has been approved for use in that lamp and is supported by a corresponding manufacturer-issued approval sticker.
UNECE have stated that they will not start looking at more common headlight regulations until 2029.  As a result approved LEDr units and stickers for these fitments will not be available until after these regulations have been passed.
It seems that the pressure applied has perhaps worked in so far as Classics are concerned.  We have a feeling MoT inspectors may need reminding of this though.
The revised regulations can be read at the following link referring to section 4.1.4: https://www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehicles/4-lamps-reflectors-and-electrical-equipment#section-4-1-4
I then asked Darren the "what-if" your car had H4 Halogens fitted which were replaced with their LED bulbs and his response was: "As long as the MoT tester has fully read the regulations and the LEDs are adjusted properly, you should have no issues."
Impressive follow up. And good news. Thank you Steve for sharing.
Could someone please clarify ...
Most of the above seems to refer to replacement led bulbs. Can we now use replacement headlamp units like all those led angel eye type with DRL, indicators, etc., that state they have ECE marks?
(Assuming the beam spread is legal.)
Richard, I would suspect the only people who could know are the manufacturers themselves or the suppliers.
I'd not asked what you're asking of Darren as their business is LED light kits as I was just trying to get new decals for mine (& it didn't occur to me). I have seen a couple TRs with full replacement units, but they're ghastly expensive (to my budget) and I suppose would have the same caveats of proper alignment to be legal/pass a MoT...
Shame they havent attempted to do anything about the dazzling problem of moderns.
