Hello all sidescreen owners.
I don’t actually need to remove either of my front trunnions, (although one is leaking a bit at the bottom) but I had a thought the other day.
Having done it before I know what a faff it is to remove the things as opposed to doing the same job on a TR4A and newer.
It requires complete removal of at least one of the lower wishbones, and (Possibly?) the spring pan as well. So long ago I did it I forget the full details, but I know it is harder than on later cars.
All because the trunnion has the pivot bolt fixed permanently to the actual trunnion.
Would it not be possible to modify the trunnion by removing the pressed-in pivot “Bolt” (Big sledge hammer, off the car, of course), and replacing it with a bolt (and tube?) similar to the TR4A.
Anyone done it, or is it a silly idea?
Charlie.
Edited by Charlie D
8 minutes ago, RogerH said:
the TR4 has the same trunnion as the 2/3 -fixed pin.
Roger,
I always thought that the change started with the 4.
Thank you for the clarification.
I have now edited my post to say "4A" instead of "4".
Charlie.
3 hours ago, RogerH said:
Hi Charlie
the TR4 has the same trunnion as the 2/3 -fixed pin.    Why not consider updating to thr TR4A spec if possible.
Does that not mean changing the vertical link ?
Apologies, because my mentioning the TR4 maybe caused some confusion.
I'm asking about  keeping the original 2/3 trunnion, (and therefore the vertical link)  and just getting rid of the solid "Shaft" through the middle.
Is it just pressed in with a spline in the middle, or does it have any larger protrusions and have the trunnion cast around it?
Anyone ever tried to press it out?
They are a press fit.   Used to sell the pin as a spare part and offered a pin replacement service.
Replacing the fixed pin with a bolt is not quite that simple as the pin must not rotate in the trunion.  The pin is effectively 5/8” diameter with a raised spline in the middle.   You could lock the pin using a grub screw set up I suppose.
Methinks fitting TR4A-6 v post and trunions (+ the also required upper and lower wishbones with ball joint) will lower the car about 3/8”
Hi Charly,
I don’t own a TR2-4, so take my comment with care.
The TR2-4 front axle with the solid bolt the nuts on both sides are locked tight and then both re-opened 1 or 2 flats (check the manual, please)
—> it is adjusted with play and this is correct, the bold CAN’T move in the trunnion anyway
The TR4A-6 axle with the slack bolt and 1 nut is also locked tight, but the nut NOT opened anymore
—> the neeeded play comes from the suitable to each other sleeves, bushes and dust shields
—> adjust it slack and the bolt moves and grinds in the trunnion
If you want to go from a tight to a slack bolt you must find a way to get it really again again and with play anyway too.
I would not do that, let it like it is (much more simple)
Apart from that I‘m convinced most of all TR4A-6 have this wrong assembled and slack instead of tight (and drive anyway, somehow)
59 minutes ago, Z320 said:
Hi Charly,
Agree
Many TR4A-6 front suspension trunion bolts are left loose as the assembler felt the tightness of the correctly assembled suspension was wrong.  The issue is more to do with reproduction parts being the wrong thickness or length upsetting the required clearance of a correctly assembled and torqued suspension pivot bolt.
Around forty years ago I modified the trunnions on my TR3 to accept the later 4A single bolt assembly. I purchased a pair of new TR3 trunnions which had the splined pin removed, then bored out to take a phosphor bronze bush with a bore to match the bolt. The TR3 bottom wishbones were replaced with 4A items. I am still using the same trunnions today, now with poly bushes in the wishbones rather than the original 4A plastic type. The top TR3 wishbones and top ball joints were also replaced with 4A type items. Controversially, I have used copperslip in the trunnions for the same period.
When the 3 was used regularly for Hillclimbing in the 1980s the front suspension was stripped down annually for a check, it is now every few years as the annual mileage has decreased and the 3 is retired from competition work, last done two years ago with nothing requiring replacement. It really does just take minutes to remove the bolt and take the trunnion off the vertical link as opposed to the faff with the original TR3 trunnion.
I did try fitting a 4A vertical link and trunnion to the 3 but it dropped the front far too much in my opinion, from memory it was considerably more than 3/8" and it just did not look right.
The above is my personal experience and should not be taken as an instruction.
If anyone really requires it I can provide images.
Cliff
The tr3 trunnions have 0 degs castor angle. If you changed the upper wishbones  & ball joint for 4A ones, they are setup for a 3 deg castor angle, so I don't see how that could work. You would have needed late TR4 trunnions, which do have the 3 deg castor. & normaly the fixed shaft in them
At least at my TR4A trunnions, with the steering stop already bolted off,
it is still not possible to turn the trunnions off from the vertical link,
without dismantling the caliper brackets off from the vertical links.
When I did my overhault I‘ve been adviced to avoid the „mistake“ (mistake or not?),
and work like this:
- 1st bolt the trunnion fully on the vertical link (1 turn more)
- 2nd install the caliper bracket
- 3rd check: the trunnions are not possible to turm off that way
- 4th fit the steering stops
IMO the front axle is a source for multiple „doing different“.
TR4A trunnions
Thank you Peter. Saves me cutting one in half to find out.
Maybe instead of a grub screw a cotter pin could be used.
Marco, yes you are right. I was thinking more about "Is it possible". I do wonder how often I would need to remove the trunnion in the life of the car, so easier to keep the design.
Cliff. So it can be done, but by having to change upper and lower wishbones as well means a lot more work initially.
Hi Bob,
You are, of course, correct. I should have explained that I have used four front 4A top wishbones and have distance pieces between the wishbones and the top ball joints so that the vertical link is vertical. In hindsight I probably should have used the TR4 trunnions. I also welded up the holes in the top wishbones for the top ball joint and then redrilled them to give 1.5 degree negative camber.
Hi Charlie,
The top wishbones do not necessarily have to be changed, the original 2 / 3 type can be retained. I used 4A bottom wishbones because I had them available. The original 2 / 3 type have bushes which would have to be removed, I am not sure if the actual bores of the two types of bottom wishbones are the same, if they are the original items could be used.
Cliff
1 hour ago, Nigel C said:
I pressed mine out and fitted bolts 25 years ago, excellent mod.
Brilliant, Nigel.
I wonder why more people have not done it.
Next time I see you at a show I'll crawl under your car, have a look and quiz you on it.
Will you be doing "Coffee and Chrome" or the "The Bowling Green " next year?
Charlie.
"crawl under your car" you'll be lucky, the police officer with a mirror on a stick couldn't get it under when checking vehicles boarding the ferry on the I.O.M😂
yes I'll be out and about and you're welcome anytime
