Afternoon All
Yes basically I am in the process of going through my newly acquired 4a. The car is in good condition,however it hasn’t been used very much for many years.I have had to replace both the clutch cylinders ( Thanks Rich) and have just sent the twin circuit brake master cylinder and the servo to Past Part for refurbishment.
Next is the cooling system.I soon discovered the heater return pipe bracket connected to the manifold had broken and the pipe was leaking at the joint. I can also see evidence of leaks around the water pump and the thermostat,so it’s all coming off.
Before ordering all the parts I’ll require I was hoping someone can identify this hose type as it seems in good condition, the same type on the bottom
Cameron
Cameron - if you can wait till 14 Nov, I will be back from my hols by then - and reckon I have most if not all the parts you require is stainless heater return pipe with bracket , hose, water pump (reconditioned by EPS), refurbed  thermostat housing ( both parts) plus heater hoses inside and out of cockpit and the bulkhead bracket cheers Rich
ps I’m abroad so only use WhatsApp messaging or phone calls
I would say that the hose type is silicon, I have the same on my car, they do last much better than the ordinary type.
In my experience another advantage of  silicone coolant hoses is that they have an element of self lubrication and are much easier to remove from a spigot or outlet if ever required, e.g. to drain a rad. This is in marked contrast to the OE rubber hoses which after a while seem to stick like the proverbial to the blanket.
Thanks both, nice to confirm there are silicone and worth sticking with.
Edited by Oddball
