dave bailey Posted November 2 Report Posted November 2 Hello all. A question for anyone who has tackled this before, (particularly Stuart). I'm about to remove all the outer panels from my TR5 rebuild (all of which have been removed previously for repair) prior to sending the body tub off for media blasting. Before doing that though, I really need to sort out the door gaps on the drivers door. The main problem is the tightness of the gap on the forward edge of the door. The thing is that the front wing is as far forward as possible. The forward alignment with the bonnet/grill/ front valance is really good. The door is as far back as it will go (on the striker plate). So I'm contemplating cutting the rear edge of the wing parallel with the door. (as shown by the blue line on photo 1). I would then mig weld a bead down the edge, and sand it flat. (photo 2 shows where I would add a bead of weld on the rear of the door to improve the gap). I'm wondering though if the welding heat might distort the rear edge of the wing. The alternative I'm pondering is to cut the edge down, but use lead loading to rebuild the edge, is this a do-able option? All comments appreciated. Dave. Quote
stuart Posted November 2 Report Posted November 2 Are you having the outer panels media blasted? If so then I would leave this until that has been done and then see how everything fits after. If you not media blasting the outer panels then I would lead fill the rear of the door edge and once youve ground off the front wing edge I would finish that with lead as well as its easier to get a proper line on it. Also FWIW to allow a nice tight gap on the front of the door to the wing and still be able to open the door without it catching at the swage line then look behind the wing at the point of the swage line where the fold is that holds the return plate in and you will see a lump of braze just there, grind that away to the minimum possible and on the very forward peak of the swage on the door just body file the very end of the peak slightly rounded, its not noticeable but makes a lot of difference to any possibility of that little peak catching and chipping paint when first opening the door. Stuart. Quote
dave bailey Posted November 2 Author Report Posted November 2 Thanks Stuart. I'm not having the wing blasted, I'll be preparing it myself. I'm interested in how the lead filling process would work on the edge of a panel like this. So I've drawn out a diagram of how I suppose it would be done. I'm just wondering if the lead will be secure on the edge, as the outer surface would have to be filed very thin so it wouldn't show! Dave. Quote
stuart Posted November 2 Report Posted November 2 (edited) Once tinned correctly on bare metal any lead will stick like the proverbial. you can see in these pictures how its only barely discernable on the outer edges of these panels.When I used to do demos at Internationals I would deliberately add like an inch or so to the edge of a panel then file it up so it was the same width of the door or wing skin and then hit it with a hammer on the edge to demo how well it was adhered, yes it would bend but in the same way that a panel would and then you can just hammer and dolly it back into the correct line. Stuart. Edited November 2 by stuart Quote
Richardtr3a Posted November 3 Report Posted November 3 Very good expert body work. The finished gap is better than most TRs that I see at meetings locally. Well done Richard Quote
dave bailey Posted November 3 Author Report Posted November 3 Stuart, thanks for the photos and advice. I'm going out right now to give it a go! Dave. Quote
