Dave McDonald Posted November 2 Report Posted November 2 I’m restarting the restoration of an early 1971 USA TR6. I first began over 16 years ago, stripped lots of decrepit trim, rubber hoses, etc, and did the conversion from LHD to RHD. Then life took over and I left it dormant until now. The car was on twin Stromberg carbs. Today I removed the fuel tank. The main fuel feed is a single connection on the bottom of the tank on the left. There are two L shaped hose connectors on top. One back left and one front right. See photos. Were these connections for something to do with the US low emissions gear? I won’t be refitting that gear, so can I just blank them off, or even just run a hose joining the two together across the top of the tank? Quote
poolboy Posted November 3 Report Posted November 3 That's part of the "EVAPORATIVE LOSS SYSTEM" for the 70-71 models. https://mossmotors.com/trs-016-evaporative-loss-tr6-1970-71 Quote
harlequin Posted November 3 Report Posted November 3 As Poolboy said it's the tank vent and it needs to be open! The safest thing is to re-plumb it down to the front offside and if you can find the separator and a carbon canister connect it up, that way you'll avoid petrol smells in your garage and fuel escaping in an accident. Also don't throw away the Strombergs, they are very good carbs and will give as much performance as SUs with less fuss. George Quote
harrytr5 Posted November 3 Report Posted November 3 Surely the fuel cap just needs to be the vented type and close off those vent pipes for good, unless in your State it is in the regulations. Regards Harry Quote
stuart Posted Wednesday at 11:01 AM Report Posted Wednesday at 11:01 AM On 11/3/2026 at 8:30 AM, harrytr5 said: Surely the fuel cap just needs to be the vented type and close off those vent pipes for good, unless in your State it is in the regulations. Regards Harry Correct, US evaporative emission laws didnt allow for any venting through the cap which is why we often get people on here having trouble with replacement cap seals that are blank without a vent hole. Dave just blank them both off and fit a UK market cap. Stuart. Quote
Dave McDonald Posted Wednesday at 01:39 PM Author Report Posted Wednesday at 01:39 PM Thanks for replies. That’s what I thought. I’ll block the elbows and fit correct fuel cap. I did find a long nylon tube running along chassis and various tubes and connectors to distributor and carbs that I assume were all once part of the evaporative emissions system. I also found the carbon canister that I removed from the front of the engine bay many moons ago. See photo. Quote
poolboy Posted Wednesday at 02:00 PM Report Posted Wednesday at 02:00 PM Some of the things you just described above were evaporative loss components, particularly the tube from the fuel tank to the Carbon Canister. The other ones associated with the carbs and distributor are EMISSION CONTROL components. Elimination of some of those are going to require you to compensate in some manner for that, mainly because their effect on ignition timing and vacuum sources. You'll find the original configuration illustrated in catalogs such as MOSS in the "EMISSION CONTROLS" section of the catalog Quote
