Hi
My car has never had a soft top or hood. It was supplied new with the HT and Tonneau only.
We are doing an event next year where having a soft top would be preferable. Looking at the usual suspect for sourcing a Fawn hood is proving interesting, especially if you want a three panel hood ( correct for early 3a's) with the correct additional front flap to help prevent water ingress.
Does anyone know where these hoods can be sourced?  I have tried Trshop, Coventry Hood.
Or does anyone have photos of the front flap design such that a trimmer can make the hood correctly?
Many thanks
Iain
Hi Iain,
I had the soft top for my TR3a made at Autotrim in Ivybridge. They didn’t have anything to copy so it’s not concours but it doesn’t leak - even along the top of the screen and it’s been driven in some absolute downpours (at times for hours on end).
Alternatively,  Robbins Hoods in the US used to offer a sidescreen hood that included the double flap at the front.
There was a video on uTube that showed someone in the States not understanding what it was about and cutting it off.
Fitting a Robbins hood
Edited by Ian Vincent
Thanks for the ideas chaps.
Ian, yes I recall that video😂. Also you guys getting caught in a downpour on the LBL in 2019.
Iain
45 minutes ago, BlueTR3A-5EKT said:
I think your next challenge will be colour matching sidescreens to the soft top.
I think you are correct Peter……I’m coming to the conclusion that the hood will have to be made by Catcott Garage who did my sidescreens.
Yes that would be very wise.   Do not forget that the quarter panel peg is further down the panel on a wedge sidescreen car compared to the Dzus sidescreen set up.   Meaning longer flap to go under the sidescreen rear edge.
Attached are photos of the front edge sealing methods I have samples of.   The black hood is AMCO from USA.  The whiteish one is Car Hood Company.   The Car Hood item is a furflex but is not far enough forward to make a good seal.  The AMCO item has just a small plastic tadpole that does sit on the screen frame top rubber and helps with rainwater sealing.   My memory says the factory used a foam sponge sewn inside a long ‘pillow’ that was attached so it sealed all the way across by sitting on the top of the screen frame.
I also have a sample white hood for a Dzus 3A  that’s white with no Windows.  It has no front edge sealing methods.   To match it I have a new pair of Coventry Hood repro Dzus sidescreens in white tgat are new but scruffy.  Never been on a car other than to test fit on my car, and they did not.   These all need rehoming.
Maybe of interest to you Iain is my new but scruffy StanPart Black Wedge 3A rh sidescreen   New but has a broken front Perspex.   It was a sample I lent to Coventry Hood to copy many years ago.   It needs a new home as I doubt I will use it.
Some hood detail pictures from a Double Duck hood I picked up many years ago at Stoneleigh, it had been made by a German trimmers that Rimmers bought out sometime in the Nineties, really well made and the Tenax fasteners were something to behold, much better quality than you get here these days,its was the only sidescreen hood Ive ever seen with a zip out rear window. I sold it to someone on here years ago. Pictures taken with it draped over my 4a hood so dont get confused.
Many thnaks for this Peter, i'm now talking to Catcott as i believe its the only way forward. As regards the sidescreens, they were refurbished a couple of years ago and am happy with those.
Cheers
Iain
Thanks for these pictures Stuart, again useful for reference. As above i'm talking to Catcott and will use yours and Peters suggestions to inform teh designof the  sealing method when they make the hood.
On a similar vein, do you have details of a source for quality Tenax fastners?
Cheers
Iain
Cheers
Iain
If you want the best then use these. https://www.loxx.shop/en/automotive/upper-parts/loxx-upper-part-small-head-chrome_627_1258
I was told that LOXX fasteners were not interchangeable with Tenax.   Metric vs imperial ball sizing.
A handy little tip ! 😉
Once you’ve got your soft top properly installed, check that the windshield wipers don’t strike it mid-sweep!
The hardtop ends right at the edge of the windshield, but the soft top extends further—if your wipers happen to be a bit too long, things can get messy fast. 😱
Realizing this while it’s raining « comme vache qui pisse » could mean ending your trip with your back soaking wet against the vinyl… 🥴
12 hours ago, Ian Vincent said:
So where / what is this soft top event?
Hi Ian
we are doing Malcolm’s Balkans Rally. I believe there’s a few places if you fancy it.
Iain
27Balkans Brochure full.pdf
Edited by iain
If you want to save a little money TRGB had up in their attic a great big pile of hoods, tonneau covers and hood bags, some new some second hand for all models of TRs.
George
The original hood on my TR3A (built only a few months after yours Iain) had a furflex weather flap but the one I purchased from Lankesters in Kingston in the early 70s had a simpler flap.  I am still using it (doesn't leak) and it is shown in the pictures.
The flap was available as a separate part which I still have somewhere.  I lent this to Pete Buckles about 12 years ago so they could get the CHT hoods right.  He sent it back with a new hood which I have never fitted but looks to be correct.
Mike
That’s it Mike.  The factory method of sealing which I had Oxted Trimming copy and pattern  for the TR 3 hoods that they supplied Cox & Buckles all those years ago.
Mike
That’s really useful Mike, thank you. Is it possible you could give me the relevant dimensions? Alternatively, big ask, could I use it to produce a template. As I said it’s big ask😀
Cheers
Iain
8 hours ago, iain said:
Hi Ian
Iain
Thks for that Iain.
I'd love to participate but I think my navigator has retired.  He struggles to climb in and out of the TR and you may remember he bu33ered his knee on the LBL a few years ago.  He hasn't got any more flexible with age. 🤣
I will try him again though.
23 minutes ago, Ian Vincent said:
Thks for that Iain.
Plenty of “lubrication” and he’ll be fine😀.
Iain
