KCL Posted November 3 Report Posted November 3 Hi, I'd just like to get some advice on my front hub nuts before I head out on the road please: After a much needed refurbishment of the front brake calipers, replacing the stub axle bearings, and generally cleaning up the area I've reassembled and put the castellated hub nut and split pin in giving what I think is the correct amount of float (hard to measure). Essentially I've put the pin in the first position which I feel no wheel movement (grabbing at 9-3 and 12-6), if I go one position looser there is just the tiniest amount of wheel movement. I know this is a contentious issue (this question isn't about setting the float on the bearings), but on both of these positions the hub nut is barely tight! I can pretty much undo it by hand and it seems the only thing holding the nut on is the split pin. Surely the only thing holding the wheel on at speed can't be the split pin, correct? Or perhaps I need to invest in a box of quality split pins!? Quote
RogerH Posted November 3 Report Posted November 3 I think you have a right to be a little concerned. The bearing assembly has a fairly thick felt dust guard/seal. When tightening the nut at what point does the felt seal feel like the nut has fully tightened!! You could remove the felt seal and see where the nut ends up when the bearings have bottomed and then transfer this info to the assembly and then back off one flat. it would probably feel on the tight side. Or simply tighten the nut till you think it has just pinched and then back off one flat. The nut will not spin off as there is a washer with a shaped centre hole to keep it still. Recheck the after a 100 miles or so to see if there is any wobble. Roger Quote
Andy Moltu Posted November 3 Report Posted November 3 Another method is to torque to 5 ftlbs and then back off to the nearest point at which you can insert the pin. Another trick when fitting new felt seals is to nip up to 20 ftlbs and leave overnight before backing off and setting. This squashes the seal. Quote
Drewmotty Posted November 3 Report Posted November 3 I like the solid spacers and shims as sold by the usual suspects. Quote
Z320 Posted November 3 Report Posted November 3 8 minutes ago, Drewmotty said: I like the solid spacers and shims as sold by the usual suspects. +1 Quote
JohnC Posted November 4 Report Posted November 4 9 hours ago, Drewmotty said: I like the solid spacers and shims as sold by the usual suspects. +2. Got rid of pad knock back on my car as well. And I feel more comfortable knowing things are nicely tight *and* have the correct end float (which must be checked periodically BTW). Worth reiterating the point Roger made: the washer should have a hole with a flat, not a circular hole, to stop it spinning. JC Quote
stuart Posted November 4 Report Posted November 4 14 hours ago, Andy Moltu said: Another trick when fitting new felt seals is to nip up to 20 ftlbs and leave overnight before backing off and setting. This squashes the seal. Best way to do it when a new felt seal is fitted as they do then squash down properly which avoids all the problem often seen with correct end float. Stuart. Quote
tim hunt Posted November 4 Report Posted November 4 +2. I fitted the 'anti knock-off' kit from TRE with proper new Timken bearings (a king's ransom but pays to fit the best) and shimmed exactly as per the instructions. To my surprise I achieved a perfect result with absolutely no play detectable by the 12 and 6 or 3 and 9 test and NO binding of the bearings. This has been the case for 50K miles now - I really should get round to repacking some time! Tim Quote
Andy Moltu Posted November 4 Report Posted November 4 The spacer kits work well enough because they allow the bearings to be adjusted correctly without overloading the bearing but aren't necessary to sort the problem. They are often sold as stiffening the stub axle but generally the issue isn't the stub axle flexing but the bearings having too much end float so the pads get knocked back when manoeuvring. Quote
