Have just undertaken an oil and filter change on my TR6. Did not notice at the time as I thought the old O ring had dropped in to the container I was draining the old engine oil into. I strongly suspect the old O ring is still in situ with the now new O ring on top, the canister is seated as it should be and I have ran it for about five minutes on tick over and there are no leaks from around the canister.
Should I remove the filter and look for the old O ring or leave it as it is so long as it is not leaking?
Remove the old one or you'll have leak and it could prove catastrophic if you are speeding along when it blows.  BTDT and it ruined a crankshaft
Could not sleep last night as it was on my mind, woke up this morning and drained the oil, removed the filter and the new O ring, and there sitting very deeply in the recess was the old O ring that I completely missed. Was surprised just how deep it sits in the engine block.
All sorted now and a test run tomorrow.
👍 Fingers crossed a problem avoided!
