J.C. Posted Tuesday at 05:12 PM Report Posted Tuesday at 05:12 PM Have just undertaken an oil and filter change on my TR6. Did not notice at the time as I thought the old O ring had dropped in to the container I was draining the old engine oil into. I strongly suspect the old O ring is still in situ with the now new O ring on top, the canister is seated as it should be and I have ran it for about five minutes on tick over and there are no leaks from around the canister. Should I remove the filter and look for the old O ring or leave it as it is so long as it is not leaking? Quote
poolboy Posted Tuesday at 09:16 PM Report Posted Tuesday at 09:16 PM Remove the old one or you'll have leak and it could prove catastrophic if you are speeding along when it blows. BTDT and it ruined a crankshaft Quote
J.C. Posted Wednesday at 03:53 PM Author Report Posted Wednesday at 03:53 PM Could not sleep last night as it was on my mind, woke up this morning and drained the oil, removed the filter and the new O ring, and there sitting very deeply in the recess was the old O ring that I completely missed. Was surprised just how deep it sits in the engine block. All sorted now and a test run tomorrow. Quote
PodOne Posted Wednesday at 05:09 PM Report Posted Wednesday at 05:09 PM 1 hour ago, J.C. said: Could not sleep last night as it was on my mind, woke up this morning and drained the oil, removed the filter and the new O ring, and there sitting very deeply in the recess was the old O ring that I completely missed. Was surprised just how deep it sits in the engine block. All sorted now and a test run tomorrow. 👍 Fingers crossed a problem avoided! Quote
